TwinTurbo.NET: Nissan 300ZX forum - I would suspect the light bulbs in the rear hatch 3rd brake
ZTicket(Dallas)
on May 10, 2010 at 11:13 AM
Brake warning light on dash
posted by NJPaul
on May 08, 2010 at 08:35 PM
light. Even if they are "working", pull them out & put them back in. Corrosion disrupts the voltage draw & the ecu might not be getting the right value back from the bulbs, making it "think" the bulb(s) are out.
NJPaul
20:35:12 05/08/10
I would suspect the light bulbs in the rear hatch 3rd brake -
ZTicket(Dallas)
11:13:08 05/10/10
light
NJPaul
17:19:12 05/10/10
short in circuit and no sensor for pads (n/m)
njz
19:49:16 05/11/10
Did you check the switch on the e-brake handle bracket? (n/m)
de944
23:30:20 05/11/10
Re: Did you check the switch on the e-brake handle bracket?
NJPaul
10:45:03 05/13/10
